I added a receptacle in a building today that was built in the 50's. Wiring is in EMT, using the EMT as the EGC. I added a receptacle by tapping off of an existing outlet. When I got the receptacle installed and I tested it my little plug tester showed and 'open ground'.
When I put the volt-meter on it I got 120 volts, hot to neutral; around 60 volts, hot to ground; and approximately 60 volts, neutral to ground. This confuses me! I've never worked in this building before so I'm not very familiar with its overall setup. I was just adding an outlet where the maintenance person asked me.
I'm not sure how you could get 60 volts neutral to ground?
Any input or ideas would be appreciated.
Thanks,
Sky
Thanks,
Sky
