BREEZY
- rockfall, ct
- E-1 electrician
Customer just installed a 2.2amp 115 volt motor for their pool.(smallest motor I've seen for a pool, but its a tiny pool) It is plugged into a weather proof gfci, the voltage reading I have at the gfci is 129 volts. Should this be of concern? 129 volts seem high seeing as the motor is only asking for 115 volts, even with a +/- of 10%
Will there be any damage to said motor?
Thank you
Thank you
