12v DC transformer for #10 wire
tallguy
Anyone have any experience using large gauge wire for 12v DC?
Dealing with an old solar system that used #10 wire. Solar has been replaced with 120v AC, but want to retain existing DC infrastructure via a transformer. Anyone know of a 120v AC to 12v DC transformer that would accomodate #10 wire? This is an odd problem I think...
080413-0905 EST USA
Your question is not clear.
Generally one does not talk about a DC transformer although in the generic broad sense of the word it probably applies.
Two major things about wire. The size, #10, relates to current capacity, while insulation and environment may alter that rating to a lower value.
The insulation and environment will determine maximum operating voltage.
If your referenced #10 wire was originally used to supply a load that required pure DC, meaning low ripple, at about 12 V and some load current within the wire rating, and you now want to now supply that load from a power supply derived from the 120 VAC, then you need to also ask the question what min-max DC voltage is allowable at the load.
If the regulation does not need to be very good, then an isolation transformer, about 10 V secondary, a bridge rectifier, and filter cpacitor should work. 10*1.414 = 14.1, subtract 1.8 for the bridge, and you get 12.3. This is only a rough calculation. If you assume a 95 to 135 posssible input variation, then that is a +12 to -21% variation relative to 120 V nominal. This pecentage variation will directly map to the secondary. To this you add maybe 10% variation due to load changes.
If you need good reglation relative to load and line, then you need a regulated power supply.
If the ouput load regulation is satisfactory with the unregulated transformer, rectifier, capacitor supply, but the line variation is a problem, then you could consider a Sola type line regulator.
You have not mentioned current or power levels.
Not the first time! :smile:
I won't have the load determined until I get a chance to see the place, some time in the summer. I'm just trying to determine if there is a product that provides a reasonable way to land a #10 wire on any "generic" transformer:
Obviously, the terminals on these are not designed to land a #10, and since the entire DC wiring of the place already has #10 in place...
The short version of a long story is that there was an entire solar system in place, that has been removed entirely, and the DC receptacles and devices are lying dormant. I'll either figure out a way to hook it into the AC system, or it will need to be ripped out (which would be a shame).
080416-0753 EST USA
tallguy:
Do you want 12 VDC to be distributed to the receptacles?
If so, then a standard transformer does not provide DC. This means you need some sort of DC power supply.
The question of terminations from #10 wire to the transformer terminals is a matter of finding a suitable crimp or other lug or terminal block.
The wire size coming from the transformer does not need to be #10. An allowable size will depend upon current, acceptable voltage drop of a short length from the transformer to termination with the #10, and acceptable temperature rise of the short wire.
There are several ways to build an AC input DC output power supply. As I previously mentioned you need to define your load requirements. Min and max allowed voltage, and max current.
If the loads consist of 10 volt incandescent lighting then there is no reason to use DC and a step down transformer will actually suffice. What 10 volt devices are there? What normally would be powered by the receptacles?
-Hal
It seems that you need to restate your OP.
What do you want?
Please restate your OP to my fifth grade level.
