12v Lithium milwaukee hacksaw
Charlie Bob
West Tennessee
does anybody have this tool?
I'm looking into buying it,i'd like to hear you all's in-put first.
I like to use it to cut 350kcmil and up among other uses, conduit,etc.
I don't owned one of those ratchet cutters for big wire, but they rub about the same price as the sallsaw, so i figure i can get more use out the sallsaw for the same money.
Thanks.
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
Thanks.
They are different tools designed for different jobs. Get both.
e57
Really? I would think that the vibration would be a handful.
And tear the end up good.... A little un-wieldy - but I use my band-saw.;) When I'm cutting up large conductors - I have usually just cut up some large pipe for them to go into - the band saw is right there... (And I'm stiff wristed enough to one hand that beast for the time being... And lazy enough to drag it out for 1/2" EMT.)
"hackzall" I saw one but am cutting down on the tool habit these days. Looks like a sawzall for mini-hacksaw/sawzall blades. (yeah just what I need - another tool requiring special searches for over-priced blades... :mad:) Looking it up to remind myself - found this review. ;)
http://www.toolsnob.com/archives/2008/09/milwaukee_hackzall_review.php
cadpoint
Durham, NC
M o
M o
I'm all for Two for One Tools!
I don't think this is a correct application verses useage, I'm not battery cutters, nor Crimpers, nor other odd tools that require a battery to complete.
The Rachet will see more uses verses a 12V Saw-all. Beside 12V is nothing to the stain that a 12V will suffer through, IE Get an 18 Volt Saw-all... Get the Rachet cutters.
c2500
South Carolina
I have one and love it...though it is a niche tool for me. It cut through a 2" cast iron drain line, using one battery and started in on another. Cutting aluminum should be a breeze for it. If you can, get the kit with the little drill/driver. I use it all the time for receptacle screws. The LED helps alot.
c2500
