12v Transformer to 12v Rechargeable Battery?
gar
Ann Arbor, Michigan
EE
190819-0909 EDT
CCinPA:
There is no information on your background.
Two factors:
1. What is your definition of a transformer? If a standard AC transformer, then the answer is no.
2. Batteries are roughly constant voltage DC loads, thus, they must be charged from a current limiting DC source. With proper design that DC source can be supplied from an AC source. That could be a 12 V AC RMS output transformer with appropriate electronics between the transformer and the battery.
K8MHZ
190819-0909 EDT
CCinPA:
Two factors:
Don't forget it takes about 14 volts to charge a 12 volt battery.
gar
Ann Arbor, Michigan
EE
190819-1168 EDT
With a 12 V transformer I have 17 V peak available. Thus, with a single diode, and current limiting resistor I can charge a 12 V battery. This needs to be turned off or reduced to a low charge rate after the battery is charged.
Besoeker3
UK
Retired Electrical Engineer
190819-1168 EDT
If it is low power you could possibly have a variable resistor/rheostat as your current limiting resistor.
A variac on the input to the 12V transformer is another possible solution.
