I bought some 14/3 Romex cable instead of a 14/2 cable to add a single outlet in my home. I'm just adding a Power Bridge type configuration so one outlet is a receptacle and the other outlet is a plug.
The single outlets have only three connections (brass, silver, green).
Should I connect black to brass, white to silver, ground to green and leave the red wire abondoned?
Can I just put a wire nut to cap the red wire on both ends and label them do not energize?
Does my plan violate any NEC codes?
Thanks in advance.
Thanks in advance.
