jeff48356
- Livonia, Michigan
Consider a 3-way switch circuit with wiring beyond the second switch. Here's the scenario: Power feeds a 3-gang switch box where one of the switches is a 3-way with the second switch and the load cable (to the light) at the other end of the room. The second switch is contained in a 2-gang box where the other switch controls an outdoor light (single pole). Which would be the best option to run from the 3-gang to the 2-gang?:
A) Use 14-4 cable (black, white, red, blue, ground), using red/blue travelers and black/white constant hot/neutral
B) Use 14-2-2 cable (black, white, red, white with red stripe, ground)
C) Use two runs of 14-2 with one constant hot/neutral, and other for travelers
If B or C, would I need to use a blue Sharpie to re-identify the white traveler?
