hardworker
Why is it acceptable to install 15amp outlets on a 20 amp 12 awg circuit?
Because no single receptacle is expected to max out the circuit.Why is it acceptable to install 15amp outlets on a 20 amp 12 awg circuit?
I presumed the OP was aware of these rules.You can only use 15 amp receptacles on a 20 amp circuit when there is more than one receptacle. A single 15 duplex would be code complaint because it is two receptacles.
Similarly low power loads are _designed_ to be safe with a 15A plug configuration on a 20A circuit.
