I always wire these as 20-amp circuits. And I usually wire them on the same circuit as a 120V outlet for a gas range ignition/electronics. This is convenient because the microwave is always directly above the range, and neither outlet needs to be (or should be) GFI protected. Besides, the manufacturer's directions call for a separate 20A circuit, and the NEC has a requirement that manufacturer's directions need to be followed. The City of Livonia inspector said that the gas range outlet is allowed to be on the same circuit as the microwave, but both need to be 20A.
