Scheffler Energy
- Minnesota USA
- Master Electrician
Hello I need some advice on a project I'm looking to put together, I have a 150 amp overhead service on a pole going to a shop 100 ft away via underground.
I want to hook up a ground mount solar array behind the shop that will be rated at no more than 200 amps my plan is to replace the standard 200 amp meter for the shop and install a 320 amp meter so I can tap the 200 amps for the solar into the meter and connect the 150 amp service there too. I would change out the mast and the wire to 4/0 310.12 for 200 amps which would be my fuse size in my solar disconnect where my solar service would start. My question is this code compliant, or would I have to make my overhead service wire bigger and size them off 310.16 After I feed the line side of the first solar disconnect I would use 310.16 to size the wires. Thanks in advance for any help.
