- Licensed Electrician
Lots I don't know either. I did not know that that the cap in HID a fixture was for power factor correction. Did you?Lots I do not know, but every HID fixture I have installed had its own cap.
Yup, caps across the incoming line will work. 55uF at something like 370 volts will work. Just make sure they are rated for HID fixtures.
I don't believe the primary function of the capacitor when in series with the lamp is PF correction either, but I also think it still does improve PF to some degree. Seems like all luminaires with a capacitor in them have fairly high power factor.I am not sure all HID caps are for PF correction.
I don't recall seeing a capacitor in an HID fixture that was connected line to line ahead of the ballast.
They always seem to be in series between the ballast and the lamp.
Or on its own winding.
Approximately.If i had 10 150 hps tights with 50% PF with on cap the line amps would be 32 amps if i had a cap the at each light the line amps would be 16 amps?
Jeez, am I talking to actual electricians? :blink::slaphead:
That's because your showing a CWA ballast followed by a magnetic regulator. CWA, CWI and Regulated lag (3 core ballasts) all use the capacitor as a method of regulating lamp wattage and limiting arc current in addition to power factor correction
Nope. I just wired it up, never thought why.
Just because you have never seen a high power factor reactor or HX ballast doesn't mean they doesn't exist.
Jeez, am I talking to someone who can follow a thread?
I will try to 'splain it to ya.
I jumped in when I read this exchange.
It seemed to me that Dave and jumper had jumped to the conclusion that caps in HIDs were only for power factor correction. I felt that might be incorrect.
I offered up some examples in my first post of what I had worked with and did not believe the caps in those examples where for PF correction.
After that post I kept looking for more info and finding the document I posted showing what you were talking about. While I have worked with many of those ballasts the caps were absent.
Never said that, I even posted a cut sheet with diagram showing one.
My point was simply that I have not been finding line to line connected capacitors in those ballasts in the real world. That being the case I doubt Dave or Jumper have been working with them either.
Capeesh?
