15amp breaker/14 AWG WIRE
PIKEY
i was told by a past journeyman that 15amp circuit/ #14awg wire can not be used is commercial/industrial buildings, only residential. i cant find anything in the code that referances this. anybody have a clue where he might be getting his info?
I am not aware of the restriction that your JW is refering to. At least not as far as the NEC is concerned.
Pete
Pete is correct, this is not in the NEC. It may be a local code or a specific job spec. Ask him for back up to his claim.
Roger
I remember way back, when I was a little helper, hearing the same thing, along with the 100'-max-between-pullpoints limit that also doesn't exist.
minimums per employer ...
where I work it is specified we use 3/4 conduit an 12 xhhw minimum ... not code but thats what they demand ... hey they pay the bills ... I do what they want ... m
i know
i know
i remmember hearing the same exact thing, i wonder if these are old rules the old timers use to use before there was a code book.
Pikey, they would have to be real, real, real, old timers, the first code was in 1897 I believe.
Here is the 1899 NEC
Roger
I love these old myths. It would really be interesting if we were able to find out how they started.
Alas, most origins are probably lost to history.
14gauge on commmercial for power supply is one of those things that is just never seen, but it's not because of a code restriction.
In alot of places, including the northeastern Ohio area that I'm in, residential projects don't have electrical prints. Residential project are inspected to code only.
Commercial projects are different in that they must have prints. Those prints must be approved by an architect or engineer (and the AHJ plan reviewer) and apparently they are taught not to include 14gauge conductors for power distribution.
Commercial (and industrial) projects have 2 minimum requirements enforced by the inspector, code and prints. We require to installation to follow everything on the prints. It doesn't matter if we think it's important. The architect or engineer stamped it. That's the way it has to be installed.
David
There was a thread a few months ago titled something like "old wives tales" discussing a lot of these myths. I'll see if I can find it.
Its sounds like a Division 16 requirement.
Typical are stranded only, 3/4 minimu size conduit, steel compression fittings, etc.
I use 14 for instrumentation and control power.
I know! They're tales started by old wives! :rolleyes:
(Oops! I hadn't seen J's post when I wrote this, but I don't feel like deleting it, so . . . )
If you haven't heard a good rumor (or code myth)by 9am - START ONE
I hear they are going to require inspectors to take a class explaining the NEC and electrical theory before they are allowed to make any inspections. I also heard it is a 30 second class because they already know it all.
Rumor has it they are going to start training electricians next.
What is a Division 16 requirement ?
It is an AIA specification section, a few others; 15 would be mechanical, 9 would be finishes, 7 would be Thermal and Moisture Protection, etc....
Roger
