I have a 15Kva 480V-120/240V single phase transformer. I am wanting to determine and calculate the required ocp protection and the conductor sizing. (Secondary is feeding power panel using both 120V circuits and 240V circuits.)
1.) What specifically determines if you are to use "primary & secondary" OR only "primary" ocp % values in table 450.3(B) ?
2.) How to size primary and secondary conductors? Is there a % above/below the rated primary/secondary current you go by?
Any help would be greatly appreciated. I have read through so many posts asking similar questions regarding sizing but cant seem to find a direct solution.
