Kessler4130
- Maryland
Hello,
My question is for a friend who works for a county maintenance department, he is also a licensed Master Electrician. There are 15 volts to ground on basically everything that is metal in a pumping station, this pumping station is connected with 5 or 6 others which are all showing the same conditions. I know the information I have is vague and more is probably needed, I am just curious is anyone else has encountered this and would know where to start in isolating the cause.
The voltage they are reading is from the metal to earth (actual soil) now I do not know what method or metering device being used to do this, it was noticed by an HVAC mechanic who was working on an A/C unit. The building is also an old nike missile site from the cold war if that is relevant in anyway. They have checked thier GEC's and neutrals to make sure everything is properly grounded, bonded and of sufficient torque, the problem remains unchanged.
I will post more information as it is available, any ideas would be greatly appreciated.
Regards,
Jesse
Regards,
Jesse
