titan1021
- Northern California
:huh:
I'm doing some work on an old house that is wired primarily with Knob & Tube. One of the switch boxes has (2) 16 gauge stranded wires that are wrapped with white threads and a black line running the length of the wire. I figured someone must have spliced the wire in the wall or attic. (It resembles the old bell wire only a little larger) So, I went up into the attic and discovered that this wire is run throughout the attic and house. It is splice and taped like the rest of the knob & tube, so I assume it is original wiring. Has anyone come across this before?
Aside from rewiring the house which I don't think the owner can afford, I figure on removing the 20amp breakers currently in place and trying to track down some 10amp breakers. Any info on this kind of wiring would be greatly appreciated.
