Hello all. I’ve been called to a home where they have been disconnected from their internet coax provider because the house coax has 160 volts between the connection to utility demarc and connection into the house. This house has no solar or wind turbine also no battery back up ups system being used anywhere within the house that I can find. When main power to the house is shut off at the main panel, which is on a pole 75 feet from the house, the coax still has 160 volts between the 2 cables and still has 38 volts to ground. I’m out of options for things to check as to how the house coax could still have that kind of voltage on it even with main power off. Any ideas are welcome. Thanks in advance!
