Alwayslearningelec
- NJ
- Estimator
Ok, here is the situation. There is an existing 1600A busway riser up many floors. The drawings said that a tap need to be made on one of the floors. It says that it can be made either with a plug duct switch or a disconnect switch. My switchgear guy said he will provide a custom box with lugs etc. to be mounted to the bust duct and we can go from there to a disconnect switch. I guess this can be done. A guy in my office said for this to be done a section of the bus needs to be removed and then the box installed. He said just for that work we should allow 50 hours. So about 3 guys 2 days plus a little more or however you want to break it up. This work is just for the box installation and not piping to the disco.
Is this correct?
Is this correct?
