Hello,
moved my neighbors tstat about 15 feet..
it's for AC.. the original stat is 18 gauge and about 20' from the air handler ( didn't crawl in the attic to locate the air handler, HO mentioned unit was right above)
I added 15' …………. I added 20 gauge, should I be good to go with the 20, or should I consider replacing it to 18?
The condenser I would think is about 70' away from the air handler if that makes a difference..
A google search http://wifithermostatreviews.com/the-thermostat-wiring-color-code-guide/
This sight mentioned it's the distance which is why 18 would be considered… Truth??
Don't loss sleep over it or replace it?
Thank you.
Thank you.
