RAKocher
- SE Pennsylvania
Somebody wanted a Cadillac when a Buick would have gotten the job done. Or they got a good deal on what they had.It was inside, above an original plaster/lathe ceiling that was just removed and there's a lot of it.
what about in 1920's?Lead is around $3/lbs.
According to the old Codes, the lead cover on the individual armored cable conductors would help to protect the synthetic rubber insulation from other corrosive agents besides moisture.AFAIK the bldg was built as a privately owned TB hospital.
Since the only thing I've seen there up till now was RMC inside the block partitions and deck pours. it did surprise me to see so much bx above that ceiling. I said the ceiling was original, but maybe not... maybe that area was renovated shortly after it was built.
One foot of this stuff weighs 5.86 oz. (yes, I weighed it!)
That’s 92 lb.’s for a 250’ coil of #14-2… Yikes!
I’ve heard there was an armored cable called AX that was discontinued and was at first wondering if this was it, but, as most have said, lead sheathed conductors must be for special occupancies, encased in concrete or UF.
More like $1.what about in 1920's?Lead is around $3/lbs.
The designations of "AX" and "BX" were the manufacturer's designation. Just like "Romex" is a tradename for one manufacturer's non-metallic sheathed cable (the Rome Cable Company, if I recall correctly.) Or, for a portable, hand-held, motorized, reciprocating saw "Sawzall" (which was a registered tradename by Milwaukee Tool).AX stood for "A" cable experimental. BX was "B" cable experimental. Guess BX made the cut.
More like $1.
https://www.lme.com/Metals/Non-ferrous/Lead#tabIndex=0
It's not going to be recycled in the 1920s. It's going to be recycled now.
I can't speak to the 1920s, but I recall the price taking a nosedive in the 1970s after it was banned from gasoline.
More like $1.
Lead by the ton? What's the per pound U.S. Price?
A lot of it being flooded-cell batteries.From what I've read, approximately 80% of lead production per year in the U.S. is recycled material.
