Smash
- Philadelphia suburbs, PA USA
This pool does not appear to have any bonding that I can see. It has a deck box under the diving board for a deck light that was removed. I see a piece of UF cable ran to behind a fence to a GFCI recenptacle and switch which customer said worked the light for years. They have purchased a 12V light as a replacement. Inside deck box is a green insulated solid #8 wire to the ground lug along with a wire to same lug goes to a ground rod near the GFCI. There is a metal ladder now a pool light and pool filter that all need to be bonded. I see nothing from the ladder cups or concrete decking rebarb and there was no bond on the filter that was replaced. Also it looks like this was all done in rigid conduit and could have been a mechanical bond when new. Problem is some of the rigid conduit has broken off at the concrete base rotted away. how can I make this pool safe so I can sleep at night. Did they bond like today in the 60s ? Can they use the pool if everything is turned off ? They won’t do major repairs to bond I know they won’t. Is there somewhere else to look for a old bond ? Can that solid ground wire be used in anyway. Right now I have a unbonded motor with no where to bond. Behind a fence where the valves are there is No heater no sweep only metal is the filter motor.
