1987 CODE GROUNDING
George and Steve,
So your telling me that if i had a commercial service that i installed and it had a continous grounding electrode conductor from the main disconnecting means to a ground rod and then to cold water pipe,meeting the ten foot in length rule,buried in the earth and there are no other grounds avaiable that it would be a code violation.?
Does it matter if i have a resistance of 25 ohms or less as long as i have two electrodes?
Re: 1987 CODE GROUNDING
I have moved this post to its original thread, and am closing this thread.
If you wish to post a reply, hit the "Post Reply" button, not the "New Topic" button.
