What is the correct conductor and cord cap size for a 1 hp 115volt single phase motor with the following motor name plate data.
this motor is rated continuous duty. S.F. 1.5 50 HZ system 115VAC 14.0 AMP s.f.a / 60HZ system 19.4 AMP s.f.a this is an internal overload protected motor the manufacturer states that the overload is sized 10 % above full load. protection code 0015.
