I am building a glass melting furnace using molybdenum elements. </font>
- <font size="2" face="Verdana, Helvetica, sans-serif">SINGLE Phase. 12kva max.draw.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">My path is:</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">240v Service Entrance, 200A main breaker>></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">60A breaker>></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Separate enclosure mounted, 200A electro-mechanical safety contactor(plenty oversize, new surplus welding contactor)>></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Semiconductor-fused 80A Watlow SCR(in the same enclosure)>></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Sorgel 25S3H Transformer, 240/480 high to 120/240 low. LVA 208.></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">120v to my elements, which are wired in series.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">A second ground wire will run from the entrance to the SCR.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">I am running a separate 120v line to the enclosure to drive the fan and the safety cut-off relay. I am in and out of the furnace constantly so I will have a mechanical switch operating the safety mechanical relay whenever I open the furnace door. (Actually, I am using a 24vdc relay to switch the 120v to the safety contactor)</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">I was going to ground the enclosure using this 120v wire run.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">I need to ground the furnace structure itself too.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Can I run the ground from the furnace to the transformer lug or does it have to go straight to the service entrance?</font>
