apjames
- norristown, pa usa
Came across a 50kva 2phase 240v primary to 3phase 240v delta secondary that needs to be replaced.
Incoming utility service to building is in fact 2phase 240v.
My question is what exactly should be bonded before trans, inside trans, and inside secondary protection breaker enclosure. The secondary protection breaker then feeds a 3phase 240v delta panel.
Primary is 5 wire 2phase (4 hots, 1 ground) secondary out is 4 wire 3phase (3 hots, 1 ground) and none of the taps are bonded. Not sure if it was even installed correctly. I'd love to attach a picture but unfortunately it's too big.
