2- 10Kw generator head phasing
artieb
Northern Indiana
Retired signalman (RR) and IBEW lineman
Hi, I have 2 Harbor Freight 240 volts,10,000 watt generator heads. I would like to use a common shaft, turning each at the exact same RPM. If both generators are in correct phase, supply 240 vac at 20Kw? Being on the same shaft, and unable to drift out of phase.
Hi, I have 2 Northern Tool,240 volts,10,000 watt generator heads. I would like to use a common shaft, turning each at the exact same RPM. If both generators are in correct phase, supply 240 vac at 20Kw? Being on the same shaft, and unable to drift out of phase.
