electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Say I have an outdoor pad Mount utility transformer and a service disconnect in close proximity to each other, let's say 8 to 10 ft. Let's say the utilities spec is typical where the secondary center tap is bonded to the transformer case and connected to a grounding electrode. If the distribution system is a MGN we will also have the primary neutral connected to the xformer can, but whether it's an MGN or a Delta shouldn't effect the answer to this question. The question is do I use the same grounding electrodes for both the utility grounding and for the service disconnect grounding, or keep them separate? Would the answer be the same if the transformer was a customer owned SDS?
