newservice
I have about 2-3 amps on my 100A single phase service grounding conductor to the underground water pipe at my house, as measured with my clamp on ammeter. Neutral current is another ~2 amps ..which does add up given the currents on the two lines. Normal? I was kind of ..shocked....at first cause I always thought the neutral, if its connected well, would take all of the current. But as a moderator points out in another thread, the pipe is in parallel with the system neutral so some current is normal. Oddly, there is nothing flowing at all on the grounding electrode conductor. I did notice last year that I got a spark when disconnecting the water pipe ground which prompted this experiment.
POCO came out and guy looked it over, scratched his head and said the line crew would come out reterminate the drop neutrals, that it def wasnt normal.. however that hasnt happened yet Current goes almost away when main disconnect turned off, still something like half an amp there and also on the neutral. Anyone going to the state fair?
