If I specify 2 circuit, 3-wire light track, for use in an interior lighting application, does the code require that the overcurrent protective device feeding this length of track, be a 2 pole circuit breaker, or at the very least (2) single pole breakers with an approved handle tie? I guess I'm asking if a run of 2 circuit light track is considered a multiwire branch circuit by the NEC.
If I need to specify a 2 pole circuit breaker to protect this run of track, can I still specify (2) single pole toggle switches (or other single pole control device) to control each circuit separately? The whole point of having 2 circuit track is so that one can control one circuit of track independently from the other circuit.
