I am replacing a robot with one that requires more power. I am using a transformer from a different source to power the new robot. The new robot will be fed from a 208Y120 transformer. I intend to use the neutral for control voltage to feed some DC supply's. The existing panel; however, already is being fed from another 120V source. Can these two neutrals be bonded, or do I need to isolate the two different sources within the panel?
