2" Emt dilemma
c_picard
USA
Sooo....
Any of you old timers, err, I mean ' experienced' tradesmen, have any ideas on how to bend 2" EMT in a pinch without an actual bender? I know, I know, I am risking banishment for asking, but it's really in the interest of history, I feel the old ways can teach a valuable lesson on why we now use benders designed for the purpose. Really.
Thanks,
You may now commence my verbal beating
Charlie
celtic
NJ
Truck/van bumpers have worked well in the past.....don't try it with a car nowadays though :D
JJWalecka
New England
Try a lull tire or something that will have some give. You will need to put many small bends. Be careful not to change the interior diameter. The end of the pipe might become damaged and will need to be cut off. Good luck.
JJ
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
Sooo....
Thanks,
Charlie
It can be done in between the dually tires on a 18 wheeler trailer. It takes great care and usually isn't pretty.
jmsbrush
Central Florida
I know this will sound like bs, but when I was a 4th year, My jw was an ox.
He could take a piece that was already bent and bend it some more or take some out by hand. By using his weight and standing on it.
cal1947
waldorf,md
retired
retired
Sooo....
Thanks,
Charlie
trees, always worked in a pinch
Rockyd
Nevada
Retired after 40 years as an electrician.
2" EMT without a bender?You are looking fro trouble! Early day Hickeys were made by shaving off the side of a Plumber's Tee, shave enough so that the pipe can be moved in and out. Don't know if it will work with 2" EMT. If it was it was GRC, you could use a back hoe, or 966 bucket and chain around a tooth, nice and slow on the curl...
EMT is an ugly one, especially 2"...
ctmike
just to put a small kick or offset I have seen it done by laying in the street and curb and runnig over with the trucks rear wheels
bjp_ne_elec
Southern NH
Sooo....
Thanks,
Charlie
Can buy factory 90s and 45s - would only use other methods mentioned in past posts for a kick or a small degree offset. Get friendly with one of the larger contractors around and either utilize his bender or pay to have some bends done up.
