I am installing 2" EMT with 1" inner duct to be used for fiber optic line that the communication utility will install. At the same time they require #6 Grounding wire to be installed to the electrical grounding system.
My question: Is it code violation if I install the grounding wire along with the inner duct in the 2" EMT? Both ends of the conduit will be open ended and will not terminate on any enclosure. The grounding wire is to bond the frame of the equipment.
Thanks
Thanks
