mshields
- Boston, MA
I'm working on the design of a building that's shaped like an L. And on the ground floor, there is the main Emergency Electrical room which is on, shall we say, one leg of the L and then stacked on the other side of the L are Emergency closets for all of the Emergency closets serving this 5 story hospital.
My design documents call for MI cable to be run through the building from the Main room to the stack of closets.
The EC is proposing as a VE measure that we underground from the Main room to the ground level closet and is suggesting that since it's outside we can do this with regular pipe and wire.
a) in accordance with the letter of the code, is this true.
b) what's your opinion on the application and it's reliability as compared to the MI inside the building?
Thanks,
Mike
Thanks,
Mike
