2 hour rated Emergency Feeders
mshields
Boston, MA
A lighting control rep recently told me that as long as we were talking about a relay panel only and not a combination circuit breaker relay panel, we could run emergency circuits through the same panel as the normal. I think they do this by providing a barrier between those circuits used for Emergency and those that are used for Normal. Regardless, is this permissible per the code or do I have to have a separate relay panel for Emergency.
Thanks,
Mike
Shoe
USA
I've done this before using the high-voltage barrier provided by the lighting panel manufacturer. It's definitely a gray area... best to check with the local inspector to be sure.
iwire
Massachusetts
Thanks,
Mike
The section is for feeders, do you have feeders or do you have branch circuits?
