2 lamp fixture with emergency battery
NavalSparkler
New User
Sacramento, CA
Maintenance Electrician
SMH
I have a 2 lamp fixture, that i am changing over from t8 fluorescent to T8 LED. It happens to be an emergency fixture, so it requires having an emergency driver and LED driver. I have 1 lamp direct wired into 277 vac, while the other wired into both drivers. When i put the lamps in, only 1 side works, either the left or the right, but only 1 at a time. I have changed out both drivers, all the same result. I have wired others in this configuration and they work fine. Both sets of tombstones are isolated, and have continuity. anyone in this small world, have across this issue?
regards,
