jim123
- new castle,de
I'm in the process of changing from two single phase 208 motors 2 hp ( 20.5 amps each) to a new system of two 3 phase 208 motor 2hp (5.5 amp).There are two 30 amp feeds coming from a panel for these single phase motors, what I want to do is to use the wires to feed the two 3 phase motors only using one 30 amp 3 phase breaker (inverse} and wire is thhn all in emt. Would I have a problem with inrush and would I have to now put a disconnect close to these motors. These 2 motors are on a controller for sump pumps . They will be alternating but there is a possibility that both could run at the same time.Thanks for your help
