bnbowen@uiuc.edu
On a current remodeling project our client wants to put all motors on VFDs. We discovered two ? 5 Hp, 17.5 amp, 208 volt, 3 phase motors on one 50 amp breaker. Our VFD manufacturer indicates that a 5 Hp VFD has an input of 16.7 amps and requires a 30 amp breaker. The panelboard with the 50 amp breaker is full. No spare space. The wire appears to be #8 TW rated at 40 amps and can easily be replaced if need be. My question is, is the 50 amp breaker adequate or should it be increased to a 60 and replace the wire with #6 THHN, 75 degree C rated at 65 amps. If the 50 amp breaker is adequate, is the existing #8 TW wire adequate.?
Also, as a side question, the motor is rated at 17.5 amps and the input to the drive is 16.7 amps. How do you ever get the full horsepower out of the motor?
