Jimmy7
- Boston, MA
- Electrician
Can you use #2 NM cable on a 100 Amp breaker? I believe NM cable can be used only at 60 degrees, so if that's the case, #2 copper is good for 95 amps. Can't you utilize the next size up rule and use a 100 Amp breaker?
