ctunison
- highland mi
I want to install a 100 amp double throw double pole transfer switch in between the utility meter and the main panel(100 amp 120/240 1 phase ) to feed from both the utility as well as a generator, the generator has a L 14 30 cord and the nuetual and the ground are bonded at the generator my question is (1) Do you bond the common neutual conection (non switched) in the the transfer switch to a ground rod (2) then do you have to run 4 wires to your panel (phase 1 and 2 ,,a nuetual and a ground) and then separate your grounds and isolate the nuetuals in the panel,also ive been told there is a danger of a ground circulation loop from the generator to the transfer switch i personally don't completly understand that terminolgy also is it neccessary to ground the generator I have got a lot of different answers from a lot of people and it has become very confusing PLEASE HELP WITH THE ANSWERS YOU GENERATOR GURU'S
