2 pole breaker on two separate circuits
wyboy
May a 2 pole breaker serve two separate circuits (Not multi wire) leaving the panel in 2 separate conduits if each has a grounded conductor. I can?t find anything disallowing this
Should not be an issue. The owner may have objection because both circuits will trip when only one is at issue.
Not really any different than having a 2 pole fused disconnect supplying the same circuits other than there is no common trip if overcurrent condition on one fuse, turning the switch off turns off both poles.
