Re: 2 Pole GFCI Breaker?
Justin connect the neutral to the neutral bar it does need this connection for the test button on the breaker to function. But do not connect the ground wire to the neutral connection on the breaker connect it to the ground bar. as connecting it to the neutral on the breaker will allow full current to flow on the grounding without the breaker tripping. there is no need for a connection to the neutral on the breaker if there is not going to be any 120 volt load. the way a GFCI works is by comparing current in the two hot conductors (and neutral if used). It does this by running all the conductors through a current coil or transformer if the current is balanced on all the conductors there will be no current induced into the coil and everything is hunky dorey. but if current happens to flow through somthing else, metal framing, your body someone else body, Etc... then the current in the conductors would be no longer balanced and current will begin to flow in the coil. When the level goes high enough (5ma.) the electronics will trip the breaker and remove the power from the circuit. thus protecting whom ever decided to become a path for the return current. This is the bases of all GFCI, GFP, and part of the circuitry in a AFCI that allows them to function.
Hope this broadens your understanding of how they work.
Wayne
[ October 29, 2003, 01:38 AM: Message edited by: hurk27 ]
