mbrooke
Batteries Included
- United States
- Technician
The advent of a standard for double insulation changed all of that.
The rule now is either grounded (EGC with 3 wire cord) OR double insulated (2 wire cord OK).
I was a mechanic in the Navy - early 1970s when double insulated tools came out. The nuke electricians were perplexed with the new double insulated drills, they had no way to megger test. It was amusing to us.
I do recall when I joined the IAEI in 1980s they had reprinted articles on electrocutions- a lot under a house with a metal cased drill.
Why? Because there wasn't tight coordination between all the various people involved.
People were removing ground prongs long past the 1950s. It was fairly routine at a facility I maintained in the 1990s.
At least for a while ... until I bought a box of a hundred grounded replacement plugs, then began cutting off "damaged" plugs whenever I spotted one.
Sometimes it was an ill-advised attempt to reduce instrumentation noise.
Usually, they didn't have a good reason. Either it works without it, or they learned it from their dad, I suppose. In any case, the practice didn't persist long after I made it a habit to never leave my office without a pair of dykes in my pocket.
A solidly-grounded handheld power tool can be a hazard if you encounter something hot. Double-insulated will protect against that, as will a GFCI.
Yah thats what I keep coming across. Metal case drills becoming live. But I can't see how so many drills would become live if the NEC required that they be grounded?
Many hand tools were double insulated with a metal case (before plastics became so popular) and no ground connection.
I remember my dad had a circular saw like that. I always thought just holding onto the metal case and turning it on was scary.
Probably wouldn't be good to be cutting into a wall or floor and accidentally cut through a piece of hot NM cable or something similar.
Plenty of tools are STILL doubly insulated without ground pins from the factory like concrete drills and grinders. Metal is not used as much simply because plastic is actually superior in many instances. Just as tough if it’s thick enough with higher flexibility so it takes impact better.
Yeah. There appears to be an exception for some heating appliances. But except for the exposed resistance element in open air they still can be double insulated.
I have seen countless male plugs where the ground pin broke before the rest of the plug even showed any wear.
Lots of different designs could have been better.
The German Shuko ("Schutzen Kontakt" ... protective) has a recessed earth conductor -- there isn't anything that can be removed, nor any reason to. It's also completely finger safe - the plug is completely recessed inside the receptacle before the pins make contact.
