K8MHZ
- Electrician
Always curious about this. Would you guys actually run 2 separate conduits from the panels to the equipment a shown or one pipe with all three circuits to a box near the equipment then branch from there. What the determining factor as to which way it would be done? Thanks.
If the prints specify separate conduits and no one has gained approval to do it differently, that's what we would run. There may be a reason the designer wanted the condensate pump separate from the A/C unit. Maybe it's a spec from the A/C manufacturer. Who knows? Bid it like it shows, and it should get run like that. If you have an issue with the design, a call to the person that drew it up may be in order. Asking how people here would do it and making changes based upon that information alone may get you in a jam.
