JDB3
- San Antonio, Texas
Having a discussion with another contractor about the rating of #2 SER al. & 4/0 URD. Table 310.15(B)(7) #2 is good for 100 amps & 4/0 is good for 200 amps. But somewhere (forgot where ??), it says wire that runs through insulation, use the 60 degree column. Therefore #2 is good for 75 amps? But also, doesn't it say something about if it is on a 100 amp or larger breaker, & terminations are rated for 75 degrees, then you can use the 75 degree rating? :huh: Please help us, Thanks.......... :?
