2 services, 1 gutter
G
Guest
Guest
Can conductors from 2 separate services occupy the same gutter or junction box? I was in a building today that has a gutter with 2 different services feeding wires to it. This doesnt seem safe.
Re: 2 services, 1 gutter
I thought that each building could have only one service unless the building is very large (which should keep them seperated) or for some reason approved by AHJ.
It's interesting that the code doesn't seem to specificaly cover this possibility however, I am having a hard time imagining why it would be installed that way. :confused:
I would think the mixing of separate service conductors would not be desired however I guess it would be left to your AHJ.
I am thinking that you have a building with seperately metered tenant spaces. Not a building with seperate services.
Are there 2 service drops?
or
Are there 2 underground service laterals?
Are you referring to two different services, or two different disconnect sources?
The building has 2 overhead service drops. 1 on the west side and 1 on the east side of the building. The building is empty. There is a gutter in the middle of the building that has conductors from each service inside of it. I cant find anything in the code prohibiting it but I can see how its not safe.
[ June 11, 2004, 08:15 PM: Message edited by: iaspiretowire ]
