Will there be a problem if I use 2 single pole contactors instead of one double pole one? My application is 1000VDC and there are not whole lot of options out there. I found these cheap single pole contactors and I am thinking of using two of them in parallel to isolate my DC bus from inverters. contactors will be energized/de-energized simultaneously.
Any problem? comment?
Thanks
Thanks
