Carultch
- Massachusetts
Given 4 source circuits, with a module maximum fuse size of 15A, with an Isc at STC of 2A, is it permissible to gang up all four circuits with two stages of branch connectors, and no in-line fuses?
2A*1.25*1.25 * 4 = 12.5A
Circuit A = Circuit 1 and Circuit 2 in parallel
Circuit B = Circuit 3 and Circuit 4 in parallel
Combine Circuit A and Circuit B.
I know it is generally the case that you can do this with two source circuits. But what about the rare situation where the Isc is so low, that a combination of four source circuits is below 15A?
The reason I ask, is I have BIPV modules with an unconventional mix of voltage and current. So I need numerous source circuits to connect in a code-compliant manner that is much more than combiners and inverters at this scale are built to contain.
