dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
I recently did some work at a couple of houses and I had a couple questions about their services.
House#1 2units - SE cable was Aluminum 4/0 (200 amp), after the dual meter socket it had 2/0 Aluminum (150amp) wire feeding 2 separate breaker boxes with main breakers of 150 Amps. I tried to read up on Service entrance rules and I could not find a way to make this OK.
House#2 - SE cable was Aluminum 4/0 (200 amp), after single meter socket it fed a splice box which mated incoming 200amp cable to a 100 amp SE cable and a 200amp SE cable, which fed a 200amp main breaker box and a 100 amp main breaker box. Is this condition OK?
Basically my main concern with both of these is that the breaker boxes combined can draw more current than the SE cable is cable of handling please straighten me out on this.
Thanks as always
Dave
Thanks as always
Dave
