PlantElectrician
- Detroit
- Plant Electrician
Hi folks!
1st newbie post. I get calls in the plant regarding bad outlets; maybe a Hi-Lo hit it, etc. I've only been here since January and a lot of the 120V wiring is original from the '90s.
Question is was there a cut-off point (NEC edition) when 2-wire circuits were no longer allowed? One I worked on yesterday had no ground. The run was rigid conduit, but I don't think that matters. I do recall when changing non-grounding outlets in a home on a 2 wire system one may use a grounded receptacle and place a "no ground" sticker on it or something to that effect.
We're going into a big shutdown and I don't know whether to pull in some grounds or not. Thank all of you and
Respectfully
Respectfully
