Huh?Originally posted by luke warmwater:
Use a 'Wiggie' between hot and neutral, it should trip.
I think you mean high impedance, BobOriginally posted by iwire:
like low impedance
like low impedance![]()
Yeah your right, thanks.
Bob
Those plug in testers usually also indicate the absence of a ground. It seems to me that the HI would know enough about how the tester functions to realize that without the ground it will not trip a GFCI, and then just use the test button at the device to perform the test. Does anyone actually use those little sticky labels that come with the GFCI that indicate "GFCI protected" and "No ground present"?I am certain that if he pushed the button and did not get a trip, he would have written it up as "no GFCI."
Yes we do. Two different inspectors got us on two different jobs. HO removed the stickers on the first job. Second one the inspector was blind and couldn't see the lght blu on the plates. He also wanted additional grounding on a sub-panelDoes anyone actually use those little sticky labels that come with the GFCI that indicate "GFCI protected" and "No ground present"?
charlie b said:When I see the name Wiggy (An old brand name) I think of a solenoid operated voltage tester rated 120 to 600 volts.
I do not know what they draw at 120 but no doubt well above 5 ma.
At 480 they draw a pretty good arc.
Here is a Square D version, I think they bought the Wiggy name.
What I have done is use a known ground, plug in an extension cord, insert one of the probes from the "wiggy" into the ground hole and the other probe into the "hot" on the GFI receptacle. TRIP I use the basement outlets, usually the laundry receptacle.Perhaps hot and ground?
