618electrician
- St. Louis
- Maintenance electrician
What is the biggest hole i can a 2x4 stud for wire ? (2017 nec) ?????????????????????????????????????????????????????????????????????????????????????????????????????
Yeah, tell that to the plumbers!Nail plates are an option if you need a larger hole. Just be careful if it's a load bearing wall. You are limited to how much you can take out.
What, you mean do it right the first time?!? Perish the thought!On the other hand, that is also the framer and or supers fault, because all drain locations should be boxed out. Even if it retrofit, box it out.![]()
The truth is, it was all on the framer this time. The plumber knew better, so he called the framer when he found the joist in his way, and the framer told him to just cut the joist out like that and the framer would fix it later. It was just too good a picture to spoil with that info up frontOn the other hand, that is also the framer and or supers fault, because all drain locations should be boxed out. Even if it retrofit, box it out.![]()
